Originally Posted by GrandKidsMX
Have you checked to see if the bike has spark after it dies when running for a few minutes? If you have a bad stator sometimes they put out enough to start the bike but as soon as it warms the stator coil stops working.
This happened on a brand new 125 pit bike we bought last year which is how I learned about this. New stator and the bike has run perfectly since that time.
I had to rejet for our altitude but that was expected and normal.
I'll give that a try. I'm pretty close to sea level, so I don't think altitude is a factor. While waiting for the neighbors to wake up, I decided to check the fuel screw. On the 22mm Mikuni clone, I expected it to be on the underside of the carb, but there is no screw... is this "normal"?
