Old 06-20-2019, 02:28 PM   #16
rjmorel   rjmorel is offline
rjmorel's Avatar
Gaijin , I would suggest not doing anything other then normal maintenance like oil change till you get 1000-1500 miles on it. I found my 2015 to be a different bike after breaking it in , more power , smoother, brakes seated in, easier shifting. If it dies on you when coming to a stop, it's telling you to adjust the valves. Very easy bike to have around. 17,500 miles on mine.
I think with a 2018, CSC would have done all the necessary prep work. So just ride it and get to know it.
For fun keep an eye on the coolant to make sure it was burped properly to get all the air out of the system and oil level should be fine. I haven't heard of any RX3 using oil yet.
Go over the nuts and bolts and battery terminals and make sure they are all tight.
Enjoy, rj
Live Zong, and Prosper
