Old 05-30-2019, 06:53 PM   #24
Originally Posted by Wild Dog View Post
He is right, the one for the 125-200 are not the same that the one used for the 250, but there are for the 250 too. So they will ask you what type of CG you have.
Yes, you can get more top end speed.
Both them are the 150cc version of the CG, which a 230cc CG, you can should be able to reach 85 mph. But and there is always a butt xD, there is the factor of the rider weight. As you can see in the second videos, that kid doesn't weight more than 165 pounds and has a small "frame"
I have a friend that owns a Ninja 650r and he complains that other people with similar or smaller engines goes faster than him. He weights a bit more than 300 pounds...
Rider weight generally has very little bearing on top speed once you get past the 60mph range (unless dealing with a grade). With my current head work I can get my bike to 75mph. I am a 6'4'' tall wide shoulder, barrel chested 260lb sasquatch. I have to reduce my frontal area by tucking my arms in, hunching down, and keeping my legs tight to the tank because I am otherwise a giant white sail atop a skinny steed. I am not saying that weight won't have some affect, but the dimensional size of a large rider will do more harm to top speed than their mass due to a big increase in drag. The mass of the rider will have a greater effect on acceleration.
