Originally Posted by Juanro
One other thing that might cause clicking noises, is a "loose" caliper or brake pads.
Not "loose" as in "not adjusted properly", but "loose" as in "it has a certain amount of free play in the bushings that is perfectly fine but still clicks". If you move it by hand you'll know what I mean. When rolling over small bumps I sometimes can hear mine clicking; but not if I'm braking, then it grips to the disc and makes no sound.
Regards
Juanro
thinking that might be it the sound is down low will update on sat. thanks
