Originally Posted by paulsstag
Do you have a link to the turbo you purchased ?. Thinking about something like that for my TBR7 not so much for the power but for altitude compensation as i'm riding between 6 and 8000ft. i think it takes about 3 psi to get to the equivalent of sea level which should be fine.
Yes as stated, its a vz21 turbo. These turbos run 7psi stock.
I have been doing alot of research and have decided to go blow through carb set up as most people could see by the pics. This requires the fuel bowl to b equally pressurized equal to boost pressure. Also needs your bowl vent in inlet side of carb to b blocked off or fuel will flood out of it
