RX3 12V Accessory Outlet
Danny, I use the accessory switch for LED lights I added, but it only works when the key is on. In that situation, no problem, it makes sense.
Calvarez, you are right that you don't want to totally drain and recharge the motorcycle battery. That will shorten it's life a lot and might leave you stranded. I followed your link and really like your jump pack. I already have a similar one from Harbor Freight. However, I still like to have the ability to use the RX3 battery without the key once in a while for limited time. It just adds some flexibility when I am on the road. i am aware and careful not to over work the battery. I did upgrade to the biggest and baddest AGM battery that would fit the RX3 just for this purpose.
