Old 04-27-2019, 08:51 PM   #6
sqwert   sqwert is offline
First container 2015.
Throttle would not return to idle. No lubricant anywhere under grip or in cable. Surface rust on inner cable. Cleaned with SeaFoam Deep Creep, kerosene, SeaFoam Deep Creep, blown dry, then lubed with Blaster Chain and Cable.
Poor front brake. I rarely use rear brake unless loaded and on the highway.
Rear brake a bit grabby, so "grooved" to reduce surface area. Now, very nice.
Poor headlight bulb. Replaced with 55w H4 from Walmart. That was better than CSC's LED.
Rear axle nut torqued to specs after replacing worn out chain and sprockets parted company out in the country. Fortunately, found apparently abandoned car with lug nut that fit rear axle. Made it home. Drilled nut and axle for cotter pins.
Several electrical doodads under tank and seat failed while riding in rain. Hard to figure what was good and what was bad with so many concurrent failures. Replacement parts failed next rain. Both sets of parts ran fine once set atop the fridge to soak heat to dry. Solution was waterproofing like an Everglades swamp buggy, time and money never spent on any other bike. Bike runs in rain.
Bike would run several minutes to several days without leaks, then drain coolant in minutes. Never figured why or how. Refill, ride on to next pissing match.
No idea what has failed this time, just quit at 45mph on a back road..
Sad thing is, the RX3 is a quite pleasant bike to ride the paved back country roads. Handled great once preload and fork oil adjusted for load, even better when switched to softer sport touring tires, braked good once front upgraded with CSC parts and rear modified, to be less grabby, plenty of alternator for auxiliary lights that filled the blank spots from CSC's LED, Secure luggage for trips (CSC aluminum upgrade), and really nice ride with Tako's seat cover over CSC's taller seat. Ride and performance were perfect for where I wanted to go. Even the occasional tractor lane. Those positive attributes will be sorely missed, especially since the replacement will not share them. However, I was generally missing those attributes anyway since the RX3 couldn't keep itself running without constant trouble shooting and repairs in addition to scheduled maintenance.
