Yes I am aware that this atv is an orphan haha. So both of my ignition coils primary resistance measures in spec and secondary measures in spec. I have multiple new spark plugs cr7hsa gapped per service manual spec. I dont have the exciter coil hooked up to anything but I can hot wire to an ac cdi and the bike will run but I was trying to maintain the stock setup with a dc cdi. If i test the coil positive wire coming from the cdi I should be getting somewhere around 200 ac volts?
