Old 02-03-2019, 11:55 PM   #25
Buccaneer   Buccaneer is offline
Buccaneer's Avatar
Lifan's new cruiser twin just got California CARB certification; not sure on EPA/DOT which might be delayed thanks to the shutdown since the EPA was closed. The reason I write this is because what you mentioned about the Bucaneer using. a Lifan twin meaning more engines might be available even if SSR no longer brings in the Buccaneer.
That's good to know. I think you mean this one, the Lifan V16 LF250-D:
http://www.lifanmotos.net/product/tz...-03-23/42.html
When I looked into it, it indeed seemed to have fuel injection and the same specs, so it is probably the same engine as the Buccaneer's, except for the side covers and valve covers, etc.
It seems likely that the fuel injection will be part of any new bikes using the Lifan motor.
