Originally Posted by Allinarush
I wish I would have known about the pro circuit 230. I cringe at the idea of bending a new pipe and putting kinks in it. So what I decided to do is eliminate the air box, and put an external filter on it. I already took it out... The next thing I did was cut the bolt bracket on the silencer it self about half way. Drilled a hole in it, and tomorrow will make a 2 inch bracket to mount to the seat. This allowed me to clear the frame. I will post a video or something later when Im finished.
Many people are often afraid of dents and dings in the pipes thinking they are going to somehow harm the flow through said pipes. It quite literally won't harm anything in regards to flow unless you are having to crush the pipe beyond half of it's diameter, which at that point you likely have a different issue.
