Old 06-01-2018, 11:38 PM   #140
jogirob   jogirob is offline
jogirob's Avatar
Stalling solved!
I reached 2000mi! I re-did the valve adjustment 500mi early because I was getting a little sick of the constant stalling when cruising to a stop or accelerating under load. I also washed and re-oiled the air filter with the K&N kit.
Bike runs MARVELOUSLY now.
By the way, if you've got feeler gauges that have one top number and one bottom number...with MM next to the bottom number, IT DOES NOT MEAN THE TOP NUMBER IS IN INCHES. It means you have yourself a Go-No Go gauge.
