Originally Posted by bikehelp
Ok then, If it is confirmed the leak is do to the retapped intake bolt on the Cylinder Head. The only way is to replace the Cylinder Head Assembly?
and if so how do you measure valves to determine head size? 52.4mm or 54mm cylinder head
You can repair it with a helicoil kit or a time-sert kit that fits the thread size of the bolt that came out. You will need a small drill for the job and red high heat loctite. There are vids on youtube explaining how to do it.
