Old 04-08-2018, 01:15 PM   #18
Originally Posted by pcast01 View Post
Thanks for all your insightful information. I tried to get it running and with no luck. The bike won't stay on without constant throttle with the choke on. So what could be the most likely culprit?
Well, in general, it's too lean. If you leave the choke on until it is hot and then open the choke up (turn it off) does it run better, or does it only ever run with the choke on, no matter what?
