Old 04-06-2018, 02:34 PM   #11
NickThrash   NickThrash is offline
Okay so i have gotten this far. I have taken both of the covers on each side off, even though i wasnt sure if i would have needed to or not. But where do i go from here?
I see what looks like to clutch plate, the oil pump gears and the mechanism that is attached to the shift lever that rotates and changes the gears.
How do I go about removing the big plate? this is where I get nervous because there are tons of bolts and screws that I cant tell exactly where they go to. Or which ones are necessary to come off and which ones are not
Will I have to take it all the way down to splitting the engine or would I be able to fix the gears from here if I get the stuff out of the way first?
If i do have to split it where do I start?
