Old 03-02-2018, 10:54 AM   #1
At the risk of being Debbie Downer, I encourage you to check the valves right away. Tappy valves are happy valves; they should make some noise. If there is zero clearance, you won't have the proper hydrodynamic wedge between the rocker and valve tip, which results in quick wear.
