Old 01-05-2018, 08:17 AM   #6
ttrider24   ttrider24 is offline
Originally Posted by Mudflap View Post
I suppose you could have burned up the clutch. Try removing the dip stick and smelling the oil. Does it smell burnt?
Stock gearing on the Rhino is too tall to do serious work like pushing snow IMO.
If the clutch is burned up you'll need to replace it, change the oil, and clean the oil screen and centrifugal filter. Complete clutch assemblies are cheap and a new set of clutch plates are even cheaper. Easy job too.
I purchased a whole new clutch assembly but while I'm waiting for that to come in I got to thinking. I'm essentially getting no power to the wheels at all. Could it be a transmission issue? It really feels like something is not connected because I am able to change gears without touching the clutch. But regardless of the gear I get no power since it's acting as if it's in neutral or like the clutch lever is being pulled in at all times.
