Old 12-03-2017, 07:51 AM   #11
Mudflap   Mudflap is offline
My 10 year old Taotao ATA250D was supposed to be a 250. The engine was stamped 171FMM, but it measures out as a 200 with the bore being 63.5mm. Haven't pulled the head on the Rhino to measure but there is no reason to believe the 167FMM stamp on the engine is correct. Probably wouldn't make a noticeable difference anyway.
The ATA250D used a 428 chain and the Rhino uses a 530 chain. I've switched mine to a 428 in order to get the desired gear ratio.
A little off topic, and perhaps Flashlightboy can answer this since he deals in Taotao, but is the newest Rhino a 200cc? According to their website, it is, but Taotao tends to fudge things on their website, although going from a 229cc to a 200cc wouldn't be in their best interest to 'brag' about. If I recall, the chain used to be a 520, but is now a 428?
