Originally Posted by Megadan
The VM26 clone you have has a 30mm throttle bore, which is the same as the stock PZ30. If you sit the two side by side you will see no distinguishable differences. The reason we swap to the "VM26" is entirely because of ease of getting all of the jets for it. Otherwise, there is no real benefit over the PZ30.
Thanks again Megadan for your reply and info,
YOU ROCK!
Thanks again... for the
dozenth time!
