bookieboy is correct, if you experience problems, it is because the engine was not built correctly. There should never be metal to metal bearing contact so there is nothing to "completely mate". A hard break-in would expose the problem right away while a gentle break-in may allow you to get hundreds, maybe even thousands of miles out of the engine, but, it will still suffer an early death.
Originally Posted by bogieboy
not trying to start a fight here, but if an engine is built correctly, and the oil pressure and tolerances are correct, that simply wont happen.... plasti-gage is a must when building motors....
Originally Posted by 2LZ
Like I said, break-in threads come to the same consensus as oil threads.
"In my experience", which is all I can speak from, I've seen more than a few four stroke motors lock cams in cam bearings and snap chains because the new owner whipped the snot out of a new motor and the "hot spots" seized up before they could completely mate surfaces.
To each their own............
