Old 10-02-2017, 10:43 PM   #1
Andizzle   Andizzle is offline
1st thing I notice is that the shift lever is hitting the housing. Remove the lever and rotate it counter clockwise 1 groove on the spline. It's not shifting all the way to 2nd gear. The shift lever is bent in to far and really should clear the housing.
Ok. Do I have to take off the chain cover or should I be able to just undo the 10mm bolt that clamps it down and adjust it?
