This might be your best bet for a triple tree assembly. Most of the chinese USD forks use the same diameter tubes, but I would recommend maybe calling CSC before ordering to confirm the size of the tubes to your own.
http://www.cscmotorcycles.com/TT250-...STEM-s/346.htm
Originally Posted by Tommywhite
any help on acquiring parts ? I need a rear sprocket and any idea on whats worked good. need to gear up for road use before I blow this thing up. 2015 bashan storm 250.
With a quick search I found a Storm owner that used the same XR185 rear sprocket that the Hawks use.
https://www.amazon.com/dp/B0068O5W3M...ing=UTF8&psc=1
