Old 09-27-2017, 02:49 PM   #13
fjmartin   fjmartin is offline
Install was very easy other than when I turned the head sink around to fit it's kind of wide so it blocked the ability to screw down the bulb so I had to trip just a bit off the plastic screw down ring grab points to let it get in there. As far as tuning, I just waited till it was dark and held the headlight assembly in my hands and then turned the element until the beam was perfect, pulled out the bulb and tightened the adjustment lock screw in place. Took maybe 5minutes to tune. I'm not sure if it gets hot in there but its not hot enough to have melted anything and after 1 year of ownership at 13,600 miles it hasn't failed. I like your setup with the bigger lights but I wanted lights I could have on riding on the street and didn't want to blind the other cars or get pulled over for not DOT approved lights.
2017 BMW F800GS Adventure
