Old 08-29-2017, 02:44 PM   #6
Originally Posted by Fodarr View Post
Did you trim the wave washers to match the stud with a rounded section cut off or just tighten down till it squashed flat?
Since I used a smaller stud size, they fit within the groove without needing any trim work, save a tiny little lip, which I just left on and they deflected around. The wave washers are so thin they don't take much force and bend relatively easy. You could trim them up if needed though.
Originally Posted by hertz9753 View Post
Do you have links the hardware you are using?
The studs were the Honda part number listed at the top of this page in my post. The rest of the hardware came from the local hardware store.
