Originally Posted by Jax Bashan
Hello all. I just recieved and assembled my Bashan enforcer from apscusa. I am also new to this forum looking for others that have an enforcer to troubleshoot and trade notes with.
Two questions:
1) When you start the bike with the remote electric starter without having the key in the ignition, how do you kill the engine? There is not a kill switch that I could find on the handlebars. Sticking the key in the ignition and turning it on and off does not do the trick either. I was forced to turn the fuel cock off and hit the throttle.
2) When installing the front blinkers, has anyone actually gotten them to work? I've tried many combinations in the wiring hook ups and have had no luck getting them to work.
Thanks and I look forward to hearing from yall!
There is no kill switch on the Shark either. Now on the remote start, if you hit the unlock button after its started it will kill the engine. I just used a cheap toggle switch and wired it up as a kill switch. As far as I know, none of the Brozz/Sharks came with them.
Bashan Shark, Keihen PZ30 Carb, Pilot 40, Main 120, Uni Filter, Exhaust, MSR Shifter, and some stickers.
