Originally Posted by Ariel Red Hunter
You can try lowering the needle one notch, but this style carburetor was never designed to deal with "snapping the throttle". You would have more success, if snapping the throttle is important to you, with a square slide carb, preferably a Mikuni because you can get different slide cut-aways for them....ARH
ok, i try lowering the needle one notch down. see if it improves.
