Old 07-07-2017, 03:22 PM   #3
The tt250 tree will fit the Hawk. I know that without a doubt. Speedo sending unit as well since I have seen a TT250 with a hawk tach cluster. Front brakes are a close match if not identical except for the rotor shape. Axle diameter is the same but length may be different, but a tt250 front axle is 5 bucks lol. May also need the tt250 left side spacer, but that is even cheaper.
Not too sure on the Hawk suspension travel. I have never seen any published figures from any vendor or even RPS. I would estimate around 8 inches, give or take. Maybe a bit longer. I could deal with a little loss in travel if these forks are shorter, same with height. I was considering making it into a more road oriented bike anyway.
The TT250 front wheel, brake rotor, and speedometer sending unit are the same as those on my Zongshen Sierra 200. I might be wrong, but I believe the Hawk uses the traditional, Chinese front wheel. Can you post photos of your Hawk's front wheel, et cetera.
