Originally Posted by Ariel Red Hunter
You have spark at the plug, I presume? You have compression? If the spark plug inside was wet with gas when you pulled it out, you must have fuel. Need to know a little more about what steps you have taken, so far....ARH
I did pull the plug on it and it was dry, ill got get a compression tester and a new plug, Ill grab a mulitmeter too
