Old 05-24-2017, 10:37 PM   #2
If the suspension bounces more than you wish, you can put the damping on a slower setting.
Rebound damping affects the speed at which the shock extends while recovering from compression. The shock absorber has 15 settings for rebound damping. Turning the screw clockwise slows the rebound damping. Turning the screw counter-clockwise accelerates the rebound damping.
If your forks have damping adjustment, you can experiment with the settings in the same manner as you adjust the shock absorber.
