Skin Mechanic also has a good write up on his engine bolt replacement. It should be the same for Vaders as I'm pretty sure they're all the same when it comes down to it. I will go ahead and order some replacement bolts too since this seems to be too common.
Not sure about the swing arm, but will look into it.
It is surprising that your chain is loosening up frequently. The main nut on your rear wheel should prevent that from happening right? Between that and the chain adjustment nuts, I don't know what else can contribute to that.
Originally Posted by Jrack
I measured the engine bolt when I took it out, 4''. Bought a 5/16'' 4-1/2'' inch steel replacement today. It should do the trick. I bought a lock nut and 4 steel washers as well. Not sure about the swing arm bolt. I suppose when I replace the engine bolt I could try the swing arm but I don't have a garage or bike lift. I've also had a problem with my chain coming loose. I've tightened it 2 times already and I don't ride it that much. I'm not sure what to do about it.
