I removed, what I think is, the clutch cover and took the attached pictures. The screw was not lose, but the piece with the bolt through it had some play left to right and also in and out.
The two close up pictures show the extreme of the play on either side, only 2-3mm total I think. In and out play was about the same, likely less I think.
