Old 05-21-2017, 08:59 AM   #306
goat67   goat67 is offline
goat67's Avatar
Originally Posted by Southokilla View Post
What kind of oil do you guys run in brozz 250. Just got a shark used gastrol gtx motorcycle 10w-40. Manual says use 15w-40. I put 1L in and manual says 1.1L capacity it seems a little low in the window.
I am running Shell Rotella 15w-40w Diesel. I start with 1L and then check the window add a bit more as needed.
2016 Brozz
