Fuses blow because of a short to ground .It sounds like you have an intermittent problem which will make it tougher to diagnose .I am aware of no known electrical trouble spots on a hawk ,so I suggest you go through each circuit one by one and check all the wiring for rub through insulation ,loose connections ,and broken components .
