Old 03-21-2017, 09:08 PM   #3
What carburetor do you have? Does it have the fuel enricher circuit? Is the slide mechanical or vacuum operated? If it has the fuel enricher circuit it may not be working and staying choked. If it is a vacuum operated slide you may have a vacuum leak or slide is stuck in the close position and is flooding it out. If you have a manual choke check to make sure its in the open position.
2020 Kawasaki Vulcan S
