I would upgrade to some kind of Steel Braided Brake Hose that is a few cm shorter to help take a few of those extra bends out of the original brake line routing
Maybe something like these will be a inexpensive replacement ?
http://www.banggood.com/0_5m-2_3m-Mo...p-1039252.html
or
http://www.banggood.com/60cm-200cm-Motorcycle-Brake-Clutch-Oil-Hose-Braided-Line-Pipe-p-1092407.html
Check the length and banjo bolt hole size to make sure the new lines will work
