Originally Posted by goat67
So is the steel / aluminum selection determine if the rim is steel or aluminum it is not real clear to me because I found others that specified aluminum alloy but more expensive.
Yes it is about the rim being steel or alloy. Less unsprung weight is better and the alloy wheel's had the fatter spokes. I don't know what the steel rimed wheels in the link I posted come with? I do know that the rear steel wheel that came on my bike has the thin spokes that where pulling out of my hub.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
