Originally Posted by Working_ZS
Have you tried your other key? On early bikes, I think one key is for the side and top cases while the other is for the ignition. On mine, a late 2015, they're identical.
Working_ZS is correct. If you have the 2015 RX3, you had a different key that was used to open the pannier and top case.
BTW, not difficult to remove a tumbler key or two to make the ignition key work with the pannier, but probably better to order keys from the internet (not expensive) and that way you can use the same ignition key with the top case and panniers.
