Old 01-27-2017, 03:11 AM   #11
Is that iacv something you could remove to inspect/clean? Also could you swap a donor battery to see if it has any effect on the stall? I know your bat is showing good.
Something else I was thinking , do some bikes come withe duel fuel injectors? This way it doesn't rely on only one in the event of a missed pulse if that is the cause of the stall. Probably impractical for rx3 application. Just thinking aloud
