Originally Posted by Dakados
I'm loving the posts on this forum so I'm not leaving even if nobody can help.
Good attitude!
As Humanbeing and Letsride indicated, there is a stamped number on the side of the motor near the gearshift that we can interpret as displacement. Gotta get down low to see it.
The displacement is most likely to be 200, but it could also be 230. Both engines use the same electrical system and carb. As FLBoy said, a 30mm Mikuni will do the trick, and you can have one shipped to your door for around $50.00 CAD.
In the meantime, check out the Gio Beast 200 sticky here:
http://www.chinariders.net/showthread.php?t=8436
