Originally Posted by Adjuster
Just trace the headlight wiring. Unplug every connector. Look inside each connector for bent wiring pins. Remove the bulb and make sure it is seated properly. Don't be intimidated by all the wires. For the most part they will all match up color for color and plug to plug. I would also take this time to put some dielectric grease in the wiring connections. Jiggle the headlight switch around to see if its a possible bad switch, China bikes are notorious for bad/weak switches. Don't assume the bulb is not burnt out because it is new. Definitely check the bulb.
Do you own a 12v circuit tester and a multi meter? Easy to learn how to use YouTube videos. Should be in every China bike owners tool box.
http://www.harborfreight.com/612v-ci...ead-61652.html
http://www.harborfreight.com/7-Funct...ter-69096.html
http://www.harborfreight.com/85-gram...dge-93744.html
Thanks for the information. I will give it a crack when the weather clears up, thanks again!
