Originally Posted by jbfla
2LZ, I read your experience with trying to remove the rotor from the stock wheel.
I'm trying to do the same thing now with no success.
Tried a heat gun on max setting for 5 minutes, then used my battery impact driver. No luck budging any of the bolts.
I'm thinking of using a torch....
I ordered a new stock rotor and bolts from CSC, thinking I would never get the old one off.
jb
I read in the tutorial that if you use a torch like Gerry did, make sure and not hit the spoke ends or it will wreck them.
I know I may be repeating stuff here but you're going to have to use a 1/2" air gun on them, with a nice sharp allen socket, with all your weight on it. It's the only way I got mine off. My gun was turned up on "high" too...and I still stripped two of them. Super soft, like unbelievably soft metal. I guess it's for expansion/contraction purposes?
If you don't have that available, take a grinder to all the bolt heads. You'll dig into the old rotor a little but you aren't re-using it anyway. Then peel the rotor off and grab the shanks with vise grips. You may want to re-heat the shanks for a few minutes each prior to trying to remove them.
Good luck and keep us posted!
