Old 08-30-2016, 12:35 PM   #1
Mudflap   Mudflap is offline
How to mount a 12T 428 sprocket on a CG engine?
I've got a 13T on there now which required some grinding on the retainer and use of socket head screws instead of hex bolts, but would like to use a 12T. The problem with the 12T is there is not enough space for a stock type retainer as the chain plates would contact even socket head screws. The only solution that comes to mind is using a spacer behind the sprocket to hold it in the correct position, and a snap ring to hold it all in place.
Anyone have a better idea?
