You will probably need a "Chain Breaker"
http://www.harborfreight.com/heavy-d...ker-66488.html
and something to cut/grind the rivets down a bit before you use the "Chain Breaker"... of course that's only if you need to remove any links in the chain
The video they change out a 520 O-Ring chain, the 428 chain on these China Bikes are a little easier to change out then a O-Ring 520 Chain
