They all share very similar attributes and generally are very similar. As almost all china dual sports will use 1 of 2 engines honda clone engines. There are always exceptions to this rule. The big differences are in quality from the manufactures. Haosen manufactures both the hawk and the hawk's engine. Where as the Dongfang uses a Zongshen engine that is epa certified for street use. In china supply chain is everything so typically vertical integration produces a better product but if you have good suppliers ( like Zongshen) then that is not always the case. The TT is still going to be almost $2500 out the door.
