Originally Posted by 2LZ
Just in case, I'd stick my finger down into the carb area and push on the little black plastic choke flap to ensure it's all the way off. I had some cable issues with mine prior to switching to the Mikuni. The little thumb flipper up on the bars worked loose and the choke flap wasn't witting right. Once I got the Mikuni, I eliminated the cable. Just as easy to flip the choke on the carb.
For what it's worth, I really like the Mikuni I put on my Rhino. I think I have it a wee bit rich but jets are readily available.
I will check that out then. I did use the choke to start it. It may be that flap. I put my finger up there and see if I can feel anything. (I feel like I should be a proctologist or something)
