Originally Posted by BlackBike
Good copy, mine is worthless. At 7 miles on the odo I have traveled 11 on the gps. And of course the MPH is a joke too. I have damaged it to by over tightning but never worked worth a dam in the beginning either. Want to replace with a electronic that can be calibrated. I always have the Garmin mounted so it's acting as the replacement.
I may give the lube thing another try too.
Just FYI, Should know within a few days if the speed sensor i'm having built will work properly on the TT. Then the clusters i have will bult up and go!
