Bolt on no mods oil cooler? Any intrest?
Working with a manufacturer in China on a bolt on oil cooler. Just wondered how much interest their would be? It will mount vertical on the left side of the bike along the frame rail. Dimensions of the heat exchanger are as follows:
8.75"tall
2.5" wide
1.5" thick
It will be of a stacked plate design so you can pressure was it without bending fins. Mounting it off to the side of the tire will allow full air flow while keeping a lot of the grime off of it. It will come wit replacement valve cover, hoses, custom mounting brackets and of course the heat exchanger.
Price will be dependent on what kind of volume i can order but tentatively looking at around $75 + shipping. A little more than the Bangood ones you can order but like the tach cluster i designed, it will be bolt on, no muss no fuss.
FYI, Also looking at inexpensive handguards and larger footpegs. Please chime in and let me know your thoughts.......
