Old 04-28-2016, 10:28 PM   #2
Originally Posted by Mudflap View Post
Try turning the crankshaft so the rockers move into a different position.
Originally Posted by mq1991 View Post
Mine required a little fanagaling, but it came out without much trouble. Try pulling it out towards you and rotating it down, it should come out. Ill try and get a video of mine tonight.
I agree with these two gentlemen. Turn the crankshaft to TDC on the compression stroke; this will release any pressure from the camshaft on the valve rockers. Then pull and rotate the valve cover until it comes free.
