I use wax. Seems to hold better. You will get every response you can imagine. Some use one, some the other, some use none. I use the wax. I only clean my chain every few thousand miles. I use mineral spirits,use wd40 to displace the water, wipe it off, let it dry. then wax. The wax seems to hold better on a warm, freshly ridden chain, so I do it after I ride, or every couple hundred miles, or after a ride in the rain. I use Belray wax.
I tried Lucas chain lube, and that stuff flung EVERYWHERE. I would not consider using it again. My back wheel was black. I want the product to stay where it's going to do some good.
