Got swing arm torn down and removed the two bushings. They were definitely done for, the rubber inside was pulverized. But, all I could get out was the smaller tube that the axle bolt goes through and the rubber.
Now I have a question, because it looks like inside the pivot point there is still a sleeve:
If I do need to remove them, are there any particular tools or tricks you can recommend?
