Originally Posted by RedHawk47
... CSC is offering a "quick oil change" kit. I'm guessing that it gets installed in place of the magnetic plug; is this right? How much of the 1.7 quarts will drain out the magnetic plug hole if you haven't opened any of the others?
Thanks,
Dan
You are correct, Dan. The magnetic oil drain plug is replaced when the "quick oil change kit" is installed.
![Wink](images/smilies/windfk.gif)
The installation, and operation of the oil change kit is described at the following link.
https://www.cscmotorcycles.com/Artic...les.asp?ID=287
This video also describes the operation of the oil change kit.
"Never argue with an idiot. He will drag you down to his level, and beat you with experience."
Mark Twain
Mods made to my Zongshen ZS200GY-2:
http://www.chinariders.net/showthread.php?t=6894
